1995 4l60e HD Questions
Since the pack is tight and it's used for towing, never racing, I think I will reinstall the release springs, but with shortened retainers so it doesn't bind as the clutches wear. I found this video on youtube and it almost convinced me to leave them out, but I figure with the shorter retainers it might be better.
Like some, but not all, I think the release springs do reduce friction wear in 1st and 2nd gears, especially with a tight pack. I had heard of concerns over the retainers and benefits of shortening them.
This is my first 4 speed auto rebuild so it's a slow learning process, and I do realize that by doing it myself the likelihood of having to R&R the trans more than once is pretty good. The information here though is very valuable, even for someone who is just doing a low rpm build. Also I can post things I am unsure of and if no one replies or stops me, I figure it's pretty safe to proceed as planned. That helps a lot too. Thank you all for the help!
My home made plate.
I had some very small puffs of air going from the reverse hole to the hole they mark as torque signal. I also have some air cross leaking between the pump holes on the forward and 3-4 clutches when both drums and the pump are tested as a unit, but not when pressure is directly applied to the input shaft holes. Its not enough to cause the wrong clutches to apply but it was enough that it worried me so I wanted more advise. This was their reply hopfully it helps others too.
Now that said, in order to establish an accurate evaluation, shop air should be regulated to 30-40 psi when doing air tests. ATF can also be used (WAT) on the exiting port to help identify too much leakage. Rule of thumb is bubbles are ok, but if the fluid is instantly removed, this is probably indicative of a problem. Unfortunately this type of testing is also very subjective, and often requires a known good unit as a baseline and experience to use successfully.
Park Idle -70 WOT -230
Reverse Idle -100 WOT 260 Not moving WOT is Power braked
Drive (No movement - WOT readings are power braked) Idle -70 WOT -240. I do it pretty fast though only a second or two, so the gauge rises up fast, not sure if that a stable reading.
When in drive, actually driving and manually holding gears the pressure readings are 170 -190 in all forward gears at WOT these readings are held for a long time and there is no gauge bounce. This is the part I am unsure about as I keep seeing pressures listed that are higher on forums but they don't state how they were obtained. Since the transmission had just over 100k and never exploded I kept the electronics that were there, just cleaning and changing O-rings and seals. The pressure switch was a bear to change the seals on, but I got it. I read though that a worn EPC solenoid could cause problems. I am not sure if this is something I should look at or not if my line pressures of 170-190 in forward gears are not OK.
On a side note the transmission acts and shifts almost exactly how it did before. I think that's a good thing since the shift kit was done before the refresh. I now have the Sonnax HD 2-3 Shift valve with the hole drilled in the valve body. What a mess that was to clean up! I did the servo cover modification that PBA recommended when doing the valve. I cant feel any clunk on down shift, its a big old van though. It now has the corvette servo set to .070 band clearance. The valve body hole sizes are 2-.082 3-.097 4-.097 Band release - .093 Reverse -.093 I went back to the stock springs in the forward accumulator and the 2nd accumulator as I didn't like the banging in to gear and the 1-2 shift was just slightly too firm at light throttle with the Superior shift kit instructions. Now even with the new corvette servo, the 1-2 shift is solid but not harsh when cold. When warmed up the shift seems to soften a little, so I may play with more springs when I pull the pan to check things in a few hundred miles.
I put the case spacer in place of the anti-clunk spring because I saw it recommended a few times here by pro builders and do hear a very small clank at times. I think that just comes with the product.
It looks like the transmission is operating in the normal pressure ranges. Here is their reply, so others have a reference too. The pressures were also given a pass by a very nice transmission person on Gearhead-EFI. Also a big thank you to all who helped out here, I learned a lot. I would suspect anyone seeing 200 psi in Drive has the EPC system modified or disabled. This is far too high, and would result in harsh, abusive shift quality in a street application.
I don't know what you want to accomplish nor do I know year model PCM, and other mods. Also if the engine has a boost in power or ya plan to do this.
Most of the time, people want more PSI overall. If I had an L60e, I would do this via the BIN/Cal that can be changed in Tuner Pro. But this largely depends on the XDF file used. I've seen and edited them finding so many of the trans cals missing. I also found many of the parameters that are stated completely wrong, scaled wrong and the worst is the HEX address is wrong. IF the paramater is to change a given cal it has to be the right HEX Address.
Be careful with them.
Personally I would increase the pres in certian areas as the L60 is a bit low in the pres dept. this is intentional for Fuel Econ boost. There are a few things you should know. 1. When towing GM staes to tow in D3 not D4. In the L60 the pres/volumne in 4th with TCC ON the volume will feed the torque converter at low spds towing and starve the 3-4 clutch TO A POINT. When the trans pump spd is increased it will feed both towing. The 4L80-E does NOT have to run this way, as the capicity of the pump is great enough to feed the clutches and converter.
What you sent me looks ok with the range of the PSI. But w/o knowing power levels and what you wanna use it for I really can't say well enoug. If I had an L60/65/70 I would bump the PSI up in certian areas. Expecially the Steady State map in the cal. It runs on the border in my opinion. In L80 we had a 1.5 psi margin in all areas in the clutch capacity as L60 doesn't. I would gladly fogo the MPG to make the trans more durable.
