4l60e looses gear HELPPPPPPP
Old Jul 24, 2017 | 11:57 AM
David Montano's Avatar
Default 4l60e looses gear HELPPPPPPP
So after getting my 4l60 rebuilt I put the car back together it drives perfectly fine for about 40 miles. I go to drive the car again but after about 2-3 minutes of driving the tranny looses gear and pretty much goes into neutral by itself. I put it on 1,2,3 and nothing even if I manually shift it won't work. But when I let the car rest for about 5 mins and turn it back on it drive perfect then again all over.... I know nothing's wrong with the pump or else it would NEVER drive so that's out the window anybody ever have this problem ??? Anything helps
Old Jul 24, 2017 | 04:10 PM
bbond105's Avatar
Sounds like the trans filter is stopped up. Was the torque convertor replaced? There is most likely clutch martial in the pan. I would call the builder for warranty.
