th400 instal question
Old Aug 26, 2017 | 03:40 AM
stock ta's Avatar
Default th400 instal question
I just Installed my th400 in my 2002 trans am, I used the stock M6 cross member with the Spohn aluminum spacer. Now it looks like my tail shaft is up to high? Rear of the transmission is up about a half inch higher than the front of the trans when checking it with a level on the transmission pan? Is this normal, or is it to high?
