4L60E Cable Drive Speedometer Conversions
Old Aug 31, 2017 | 11:34 PM
alloy's Avatar
Default 4L60E Cable Drive Speedometer Conversions
I have just started doing the 4L60E-4L65E-4L70E cable drive speedometer conversions that I've added to my T5 and T56 ones I do.
This is not an adapter for a different tail housing that makes you move the cross member. I can do the standard 2 wheel drive tail housings and the 4th gen housings.
You send me your tail housing and I modify it for cable drive and send it back to you with speedometer gears and a adapter to retain the drive gear on the main shaft.
Go to www.t56cablespeedometer.com to see this.
