LS 4l60e connector voltages I'm piecing together a LQ4/4L60E in to a '95 Camaro. I've put a few miles on it and it feels like the converter unlocks and locks in any gear when throttle is applied. From a dead stop if I nail it, it revs to the moon at the 1-2 shift. And would probably act the same at 2-3 I just never held it. At light throttle cruise, it will lock in OD but with any more throttle it immediately unlock/(slips?). Feels like it does this in any gear. I found this dwg online. Unknown if LS or not. Disregard the red highlighted U. That was already on the dwg. https://cimg6.ibsrv.net/gimg/ls1tech...25ea0b26c3.jpg Can anyone tell me what I have for voltages are correct? Key on, engine off. A - = B - = C - 11v D - = E - 12v F - = G - = H - = J - = K - = L - 5v M - grd N - 10v P - 10v R - 10v S - = T - = U - = |
I'm not sure what your trying to do here?? If your using a "Breakout" method....Everything connected, Key on........... Pin U should have Voltage if this is a PWM 4L60E, The other solenoids could/can be pulled Low by the PCM. |
I had some voltage problems with the underhood fuse box. I was looking to see if the voltages I was reading seemed correct with key on engine off. I did forget to mention this is with the connector unplugged at the trans and reading the pins there. This is a Performabuilt level 1. |
© 2024 MH Sub I, LLC dba Internet Brands
