Th400 auto vs manual valvebody
1. Can they be manually shifted in all gears?
2. Seller said it doesn't have an electronic kickdown switch. Does it need one? If so, how are people setting them up on ls truck intakes?
3. Does it operate off vacuum?
4. And last but not least, for a 5xx whp 3200 lb STREET/strip car, would you prefer an auto valve body or manual?
Yes it can be controlled manually as well.
in order to have passing gear you will need the kick down switch.
Yes it operates off of vacuum, it comes with the vacuum modulator already installed.
This one is a loaded question! This is going to depend 100% on user preference. If you like shifting and banging gears you should probably go with the manual level 3, if you want a more drive to church feel and don't want to worry about having to shift gears all the time; go with the level 2 auto shift
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
much preferred to limit it to 2nd gear-never used one since, lol
