Lq4
Old Sep 23, 2017 | 10:28 AM
Charlieboy92's Avatar
Default Lq4
I'm putting an 03 LQ4 in my 2006 Silverado 1500. Also doing 4l80 swap. My question is do i need the crank spacer or not?
Old Sep 24, 2017 | 06:07 PM
clinebarger's Avatar
If your running a stock 6-bolt 310mm 4L80E converter?.......Yes, You will need the crank spacer & flat flexplate.
If your going to run a custom built stall.....Have it built for a 4L60E dished flexplate.
Old Sep 25, 2017 | 06:47 AM
Awesome. Thanks for the help
