Vibration coming from tranny ?
Old Sep 25, 2017 | 08:20 PM
z28pat's Avatar
Default Vibration coming from tranny ?
I Had some work done to my car, new camshaft and tune and they had to pull the tranny to replace a seal that was leaking. I don’t know if it’s from that or the tune but there’s more vibration from the tranny under the armrest/ cupholder
I feel it more when the car is in drive, the faster I go and the higher it revs.
It almost feels like something is tight. Any ideas what could be causing this!
Thank you
Old Sep 25, 2017 | 10:31 PM
Roxas's Avatar
Maybe the exhaust is loose?
Old Sep 25, 2017 | 11:10 PM
clinebarger's Avatar
Check for something hitting the Body like the exhaust! If the mount was replaced with a aftermarket piece.....Get a GM mount! Also check the Torque Arm Mount.
Old Oct 3, 2017 | 03:59 PM
performabuilt's Avatar
LS1Tech Sponsor
Did you replace the transmission mount ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 4, 2017 | 05:36 AM
z28pat's Avatar
The tuner had to increase the lock up speed and take away soft apply on lockup to minimize bucking and that’s creating this vibration
