4l80 swap, getting a p1810
This needs to be fixed!! You either have a wiring issue or a malfunctioning TFP Manifold, If your in the DFW area....Ill give you a known good used one.
-An illegal gear range
-DRIVE4, DRIVE2 or REVERSE position before and after start-up
-PARK/NEUTRAL with a ratio greater than 1.05
-REVERSE with ratio indicating outside of REVERSE
-DRIVE4, DRIVE3, DRIVE2 or DRIVE1 with ratio indicating REVERSE While DTC P1810 is present, the PCM assumes DRIVE4 for shift pattern, sets line pressure to maximum, freezes shift adapts, and forces TCC ON with 4th gear commanded. (Can vary depending on calibration)
Combinations......
