6L80 tap shift from 2 sources ?/help
Old Oct 11, 2017 | 12:29 PM
pt2285's Avatar
Default 6L80 tap shift from 2 sources ?/help
so i have my shrifter tap shift working all fine but my actual shifter has tap shift as well.. now i have heard that you can only tap shift from 1 source because its a resistance signal and adding 2 locations will double the resistance.. but if you were to use an ultra low resistance diode as a 1 way electrical check valve, could you use 2 sources? does anyone know the resistance values the ECM is looking for?
