B&m 70274
Old Oct 18, 2017 | 05:04 AM
Deniz A's Avatar
Default B&m 70274
Hello i am about to put a transmisson cooler to my ls1 camaro but stucked about the fittment issue i have the B&M 70264 comes with all fitting parts and i read a lot of about the coolers and i thinking about to get the 70274 does that thing fits in front of ac condenser?gonna keep the stock cooler too.
Regards all
Old Oct 18, 2017 | 05:14 AM
98CayenneT/A's Avatar
Yes it will fit in front of the a/c condenser. That's where I had it when I ran that cooler.
Just remove cooling fans, use radiator ties and push them through the a/c condenser and radiator then put fans back on.
Old Oct 18, 2017 | 05:18 AM
Deniz A's Avatar
Thanks a lot for your answer m8.
Old Oct 19, 2017 | 02:16 PM
LS6427's Avatar
Don't put it up against the condenser, you'll have a huge hot spot created there, and that hot spot will follow right onto the radiator surface.
I'm mounting two of those coolers (in series) on either side of the center post down by the ram air....as soon as my 4L80E goes in. This way the ram air from the lower air dam will mix with the hot air coming off the coolers and there won't be any hot spots created.
I have one now, on one side.....it had zero effect on my A/C temps and no effect on my coolant temps.
Attached Thumbnails B&m 70274-dsc01784.jpg   B&m 70274-dsc01785.jpg   B&m 70274-dsc01786.jpg
Old Oct 22, 2017 | 03:48 PM
Deniz A's Avatar
Hope that cooler fits like yours. Is that the same cooler or size what you have done to yours?
