TH400 swap speedo mod with ABS?
Old Oct 30, 2017 | 06:07 PM
corvette8189's Avatar
Default TH400 swap speedo mod with ABS?
Did the speedo mod to the abs wire works great. But how can I get rid of the dash lights? Anyway like you can on the 98 models?
I have abs, asr, and brake light up.
Thanks for any help.
Old Oct 31, 2017 | 01:58 AM
Game ova's Avatar
Pull the cluster.... tape the light diodes. That's what I did.
Old Oct 31, 2017 | 07:26 AM
JoeNova's Avatar
Restricted User
Can those Dakota Digital electric VSS adapters be fed to the stock PCM or were they intended only to drive a speedo?
I wonder how hard it would be for me to make a module to read the signal and convert it to work with the stock PCM to retain certain features.
Old Oct 31, 2017 | 02:49 PM
Another ?
Will the speedo mod cause my asr to light up and not work as well or is that another problem.
