1997 gmc 4l60e
Old Nov 10, 2017 | 02:25 PM
56tld's Avatar
Default 1997 gmc 4l60e
replaced inner harness , now i don`t have 1st or 4th , if pin in 1 , 2 , accumulator is out of place , would it cause this , or is it my cheap harness ? thanks
Old Nov 10, 2017 | 02:55 PM
bbond105's Avatar
Why would the pin in the 1-2 accumulator be out of place?
Old Nov 10, 2017 | 03:08 PM
coryforsenate's Avatar
1-2 solenoid not turning on? It's on during 1st and 4th but not 2nd or 3rd.
Old Nov 10, 2017 | 08:11 PM
56tld's Avatar
56tld , had to pull 1 , 2 , accumulator to r & r wiring harness , same question , could it cause loss of 1st & 4th if i got it out of place ? thanks
Old Nov 11, 2017 | 07:29 PM
mrvedit's Avatar
Moderator
The 1-2 accumulator is used during the 1->2 shift.
As mentioned, the most likely cause is the 1-2 Solenoid is disconnected, either because you didn't fully plug it in, its electrical tabs got broken or the new harness is defective.
