Vibration after Trans Rebuilt.
Posts about loose pinion bearings and a clunking rear end were in the hundreds back then when these cars had less than 36k. Ask me how I know? Because GM techs admit the 10 bolt should never have been installed in these cars because the rear ends where built so cheaply.
So the typical response to the customer when you took the car in was that they all sound that way and send you out the door up until the car would go out of warranty. After warranty, GM was more than happy to replace them.
Same for the aluminum driveshaft that had internal welding cracks and it would tick and ping when you put the car in gear. Same reply, they all sound that way. BTW - they finally did replace the driveshaft under warranty because the weld was visible externally. And of course - elcheapo front rotors that would warp too -same GM reply
As for my second reply in this thread, I thought the OP should rule out the easy stuff first then move on to the rearend. My statement "If it still continues to vibrate, then perhaps the pinion bearings are bad." is actually in agreement with you. Sorry that you didn't read it that way.
The OP's mechanic said the bearings were 'loose'. If he did suggest to the OP that they should be replaced - the OP doesn't say. Should the mechanic instead have told the OP that the bearings were 'bad' and should be replaced? IMO - if that was his diagnosis - that's exactly what the mechanic should have suggested. "Loose' IMO isn't best word to use if something is worn out and needs to be replaced.
For you, 'loose' means the same as 'bad and should be replaced'.
To me 'loose' means there is some play. Back in the day just loose wouldn't get them replaced.
On a side note; it is suprising that no one has asked the OP how many miles are on the car.[/QUOTE]
It wasnt my mechanic that noticed it but the person who rebuilt my trans. He noticed a small bit of play when you would move it by hand but not a lot. He recommended me that its the bearings or pinion yoke that would need replacing. as for the mileage on the vehicle, My 6.0 has 91k while the car has 165k. Maybe it is time to replace those bearings.
As everyone is suggesting, either the pinion bearing in your rearend and/or poor driveshaft angle is causing your vibration. And the poly trans mounts are greatly amplifying the vibration. I also suggest going back to OEM trans mounts, but even if that by itself seems to solve the problem, you should find and fix the source of the vibration before it gets worse.
I just got back from my mechanic. He took the car for a drive and he felt the that vibration. Lifted it up on jack stands to check out the driveshaft, U-joints and Pinion and it look fine. No Pinion play either. He said its definitely transmission. So at this point, What can I do? I just messaged my Trans guy to see what can he do. My mechanic said he left the car well, shifts amazing, just with a vibration.
Were either the converter or flexplate replaced?
Who installed the trans?
If you, what was the gap between the converter pads and the flexplate?
If the trans rebuilder re-installed the trans, perhaps it is time to take it back to them.
Honestly, after I see him, Im considering taking it to a driveshaft place for balancing and new U joints. I may just wait out and see if I can find another Trans locally, maybe even built for cheap but thats my option at the moment. Since my motor is a 6.0, lets say hypothetically speaking it was the flexplate, Do I buy a flexplate for the LS1 or LQ4?
What are good brands for a stock Torque Converter?
So far no trouble with the Yank. I had to have a new hub installed because of a pump failure in the transmission which took out the hub on the converter. No fault of Yank.
Yank replaced hub. Excellent service. Dave said it was still perfect inside. Got it it 2007.
IMO if you do replace the converter don't go too high. My Yank PY 3400 drives almost like stock until you mash the go fast pedal. IMO it's no fun driving in the city with a very loose stall.
Make sure to inspect your flex plate closely before installing a new converter. It might be cracked.
If your converter is bad with trash inside, that means probably that trash has found its way into the transmission and cooler if you have one.
https://www.rockauto.com/en/parts/da...converter,8668 go there and put your information in and order one.
Get a Dacco converter. Code should be TMAX or TMBX.
