Bmr TH400 crossmember help
Old Jan 22, 2018 | 08:11 AM
Brainfear's Avatar
Default Bmr TH400 crossmember help
Well I’m in the process of a th400 swap. Trans is bolted up minus the converter to flex. Problem I’m having is my bmr ta relocation crossmember isn’t fitting at all. Have a large gap on the passanger side. I’m using the es 3.1108 trans mount which I believe is correct. I plan on taking some angles tonight of the trans but looking at it I still don’t think I can fill the gap. Trans seems tucked pretty good. Anyone have any tips?
