How you do get this darn pan off?
Kyle
Kyle
You need a Torx Bit to remove the two bolts that hold the shift cable bracket to the transmission. Once you get that bracket out of the way, you can drop the pan down enough to fit between the exhaust and shift solenoids. BE CAREFUL with the solenoids, many people have broken them in attempt to remove the pan. Make sure the electrical connectors are fully seated before re-installing the pan.
