Help decoding 4l60e? Need help decoding 4l60e, Has "2KPD" on sticker on driver side of transmission I also dropped oil pan to replace pressure switch manifold as I got a P1810 code but upon removal there was no pressure witch manifold. |
Originally Posted by Jays_SSZ28
(Post 19851745)
It's a 2002 out of a 4x4. Thats about all the decoding you need. So you're saying the PSM was missing, as in removed? |
Okay, I'll take a look later today for a date cast. Right now I'm getting a P1810 code and upon tuning/test drive it would shift out of 2nd gear. Would replacing valve body with older maybe 2002 work? Maybe something like this? https://www.ebay.com/itm/4L60E-4L65E...-/122937609899 New internal harness, solenoids, PSM, and separator plate? |
Is there some type of switch that is hooked to the selector shaft on the inside of the trans? |
here are some pics so I guess it is a 2012, and there is a switch on selector shaft. would using a older valve body work to solve this issue? https://cimg0.ibsrv.net/gimg/ls1tech...177cac648f.jpg https://cimg4.ibsrv.net/gimg/ls1tech...1ceed91463.jpg https://cimg6.ibsrv.net/gimg/ls1tech...c0185e1d16.jpg |
The switch on the shaft takes the place of the pressure switch manifold. Make sure it is hooked up and adjusted correctly. Check with an ohm meter to make sure it is working correctly. |
haven' tested with ohm meter but trans wouldn't shift correctly upon tuning and test drive. would just stay in 2nd the entire time. I have it mated to 5.3 LM7 with older red/blue pcm. Do these newer trans require tcm? Also I found another thread related to this issue and they couldn't get newer design 4l60e to work properly, but they did replace valve body with one from older 4l60e could someone verify This? I'm thinking it maybe be possible to just replace valve body along with internal harness,solenoids and it'll work? |
https://ls1tech.com/forums/automatic-transmission/1360298-4l65e-no-provision-3-2-solenoid.html |
Is there a master list of transmission codes somewhere? For example, my GTO is a 6HMD, but I've only found one list and mine isn't even on it. |
© 2024 MH Sub I, LLC dba Internet Brands
