Transmission mount
Old Mar 12, 2018 | 12:44 PM
stock ta's Avatar
Default Transmission mount
I just put a th400 in my car, 2002 trans am. I have poly motor mounts. I am currently using a poly transmission mount but getting alot of vibration. Set pinion angle. Still has vibration. Car has a chassis mounted toque arm. My question is, is there a good GM 1le rubber trans mount that will hold up decent and get rid of the vibration??
Old Mar 12, 2018 | 01:06 PM
bbond105's Avatar
A rubber trans mount will help some, but you will have more vibration with that chassis mounted toque arm.
