Converter or clutches
I agree that WOT lockup is going to seriously kill the converter life. But I don't see any reason why it's even trying to lock it up???
Kindof stump'd here
In transmission/auto shift speed match the normal/Performance/cruise/hot tables to be the same as normal
Transmission/shift pressure match the normal and performance. I'd also add some pressure to 2-3
Transmission/auto tcc matchthe normal/cruise/hot/performance tables
I'd try this and reload the tune and see how it goes. Sometimes just reflashing will fix the problem also. Never had it happen on a car but some equipment at work you'd make calibration changes save and reboot and it was quite clear that the changes didn't take even though all the values we inputted were still visible. Another reboot without changing anything and the changes were there.
I rode again but took the time to setup the right stuff to log instead of the standard layout. I logged timing and torque management timing retard on the same plane, and it was pulling like 26 degrees out.
Logged torque converter lockup solenoid and it actually wasnt commanding lockup...i should have taken the time to setup tables more than what I usually use but I was a little rushed over lunch.
So. I said screw it, and used the credits...removed TM on the 2-3 And wham...no problem
So for curiosity sake, I flashed the old tune back, and tried commanding converter unlocked again and same thing...no shift issue. Watching the TM timing retard showed that when the converter was forced unlocked...it wasn't pulling timing out.
Then, when I didn't force the converter to do anything, it still didn't lock...and the solenoid didn't try to lock...but this time it DID yank a bunch of timing out. There must be something there about how the pcm calculates torque management.
So, to sum up...i flashed back in the tune with torque management removed...didnt change any other settings...and the shift is perfect...doesnt pull timing out...nails the shift and just pulls
I'm not sure how the pcm calculates and figures how much timing to pull for TM...im not sure why commanding the torque converter off would make any differences, but it seems like it did. It nailed 3 back to back WOT 2-3 shifts both times I had the "old" tune in it and commanded the converter off.
Removed torque management, nails the shift. All is good in the world.
Thanks guys, I'll just stick to building hardcore 60e's and hope I don't have to deal with "tuning" this issue ever again haha
Thanks for pointing me to look at TM. Glad I could get it fixed (and glad the trans I built is behaving great like it should)
It was in edit/view/advanced, in sure most people figured that out though.
