Converter bolts hitting the back cover bolts
Old Apr 12, 2018 | 01:27 PM
chevyz2801's Avatar
Default Converter bolts hitting the back cover bolts
I have a 01 camaro with a Turbo 6.0, tci flexplate, pro yank 3400 converter, 4l80 using stock converter bolts everything was fine no noise only seen that the bolts hit cause transmission started slipping so pulled it for rebuild. What could cause this?
Old Apr 15, 2018 | 03:41 PM
mrvedit's Avatar
Moderator
Would you like to explain that better? You might get some suggestions then.
Old Apr 16, 2018 | 12:59 AM
tug686spd's Avatar
Flex plate flexing and high converter pressure
