4l80E RCSB Silverado Yoke Question
I have read BOTH stickies covering this subject and there are about a MILLION different responses. I also called Denny's Driveshaft two separate time and got two separate answers! First time I called a gentleman said a TH400 COUNTERBORED slip yoke with a conversion u-joint 1350/3R.
The second time I called to verify and order a guy said: http://www.dennysdriveshaft.com/p108..._inside_c.html
Can someone please help me out for Christ sakes??
I have a pre-97 4l80E that I have swapped into my '00 Regular Cab Silverado. I want to use my original driveshaft. It has the 3R u-joint (according the Denny's). I had to melt the injected plastic to remove them.
I have read about the many different 4l80 yokes. Short, long, counterbored,...etc... Yet I can't seem to get a definite answer.
SO WHICH ONE IS IT?
I have a 4l80e with the output shaft FULLY SPLINED with NO O-RING
Ps. Dont use a th400 yoke. They are usually counter bored and dont have much spline/bearing housing engagement. They will flop around and cause a bad vibration! Learned this the hard way! Good luck!
So now I've got yet another answer..a long 4l80 slip yoke. See what I mean? Dang.
Thanks for the suggestion Brandon.
Just get a long one and u will be fine. U have the long spline shaft anyways. Your golden!!
Looks like the exact same thing as you. Asked and answered.
Nobody is being an ***, you're looking to be spoon fed info and then getting salty when nobody breaks out the china. Oh and p.s. he's just being sarcastic with you.
You're the one that's building the can yet cant simply cut and grind a yoke if you need to, don't make that everyone else's issue by whining on a forum and calling names.
If the above thread doesn't answer your question, then you need a LONG yoke with FULL splines. Question Answered.
Another thread on this same forum.
Part numbers and everything.
The search function and google are killer tools
Brandon6.0,
Here are some pictures of the above mentioned yoke installed. I assume since it does not actually contact the trans, it needs to be cut down? I also included a picture of the inside of said yoke.
Bottom the yoke...measure center of u joint on yoke to center of u joint on rear end with suspension loaded (read: not on a 2 post lift or jack stands on the framerails). Take that measurement minus 1.5"
Get driveshaft made at that length
