6l80e cooler I have a build with a 6l80e and wanted to add a cooler, but don't want to route it to the front of the car if possible(transmission is in the rear, stock c6 corvette drivetrain). Street driven daily with some track time. Was hoping for some input. A cooler with a temp controlled fan I am assuming. |
Originally Posted by tdishon
(Post 19929128)
I have a build with a 6l80e and wanted to add a cooler, but don't want to route it to the front of the car if possible(transmission is in the rear, stock c6 corvette drivetrain). Street driven daily with some track time. Was hoping for some input. A cooler with a temp controlled fan I am assuming. If it stays in the back, it needs a fan. If it needs a fan, you will need a way to control said fan. Yep, looks like it's all solved. There are 3 or 4 other threads in the last week alone discussing coolers. Do a search (or just scroll down) and look what has already been recommended. One (or two if you want to fit them) H7B coolers will be plenty for your setup with an appropriately sized fan. |
MaroonMonsterLS1: Thanks for the direction. I was reading through several thread and found new coolers for the front. I'm going to search through again. I figured it had to be addressed in the past. |
© 2024 MH Sub I, LLC dba Internet Brands
