4l60e transmission not working need help
SRT8.Acelleration's post is a good possibility.
- 1 gallon = 4 quarts. If that's all you added you are way low.
- Are you checking the level with the vehicle running?
- If the converter was not seated it is possible you cracked the pump when tightening the bell housing to block.
- hook up a pressure gauge and see what you have. If no pressure you probably cracked the pump. But get the proper amount of fluid in there
The park actuator is separate from the manual valve.
O.P. these are some really basic things you need to check. Make sure it has fluid. Make sure the pump isn't broken. Make sure the shift linkage is attached and adjusted.
If you can gaurantee those three things, come on back and post issues
