4l80e Swap- Shift Noid B is On All The Time
Car is in limp mode and pulled P0758 Shift Noid B Electrical and Speed Sensor.
With HP Tuners, I commanded 1-2 noid and clicks. Then did 2-3 and nothing.
Pulled the pan and disconnected the 2-3 noid. ***As Soon As you Plug it in, it clicks. Unplug it, goes off. I tested this with another known working 2-3 and same thing. They get hot when plugged in for a few minutes.
I would assume its being sent a ground signal somewhere.
Anyone had any ideas? Thank you.
Start tracing wiring. I would unplug the connector, find the correct pin, and check it vs ground. if the harness is permanantly grounded, you know which way to start looking. If the harness isn't grounded, check out the internal harness to the trans and see if a wire is worn/burnt and grounding internally.
Let us know what you find.
Never seen a PCM go bad before.
