4l60e/gear question
My question is....do I pull the trans and put the normal planet in, change the stall or put some 3.90's in the rear???
The problem is that the rpm % is about the same drop
3.06--->1.62 is a 47% drop
2.84--->1.55 is a 45.5% drop
You really think that makes a difference? Its still a huge change from 1st to 2nd
1.63 to a 1.55 is only about 5%
Don't recall which sites I read ( searched alot), believe it was some corvette sites.
when you go to shift 1-2...you have a 45-47% gear ratio drop...THATS the big downfall in the gearing of these 4l60e's
Thats a BIG rpm change
and the sonnax planet doesn't change that huge 1-2 shift much at all
if you go from stock planet and 3.70's (3.06*3.70=11.322)
and get the sonnax unit and 3.90 gear (2.84*3.90=11.076)
you don't gain much of anything (especially on 1-2 shift rpm drop)... you throw away over $1000 in just parts alone... and you're left getting worse gas mileage because your overdrive ratio of the trans is the same, but now you have 3.90 gears and are turning higher revs when cruising
I think that planet is silly
