4l60 200 firebird shifting problem
Old Aug 18, 2018 | 12:58 PM
jfrazier14's Avatar
Default 4l60 200 firebird shifting problem
2000 firebird 3.8 ser 2 auto trans.
it is shifting fine until in high gear going on level ground it wants to shift back in 3rd then going up hill slightly in a load it goes back into high gear. i have replaced both ciliniods in trans and throttle position sencer what could it be
Old Aug 18, 2018 | 03:39 PM
Jays_SSZ28's Avatar
Could be a clogged catalytic converter, or anything causing lowered engine power. Lower power requires more TPS which puts it in a different spot in the shift table.
Not likely a transmission problem.
This is assuming this is a car thats been together and not worked on recently.
Old Aug 29, 2018 | 07:48 AM
Leon Rembowski's Avatar
Default 2002 Firebird Pauses before going into first
This may not be the place to ask this but here goes.
My stepson just got a 2002 firebird and he is panicking about thee trans pausing about 1-2 seconds before it responds from neutral to drive. All other gears seam to work as they are supposed to. This is his first functional car and I am not much help on auto trans for him. I know the basics and can muddle my way but am guessing here. I am suspecting a sluggish solenoid but don't know. I don't know if there is a additive that can be added to the oil to help or if just replacing the offending shift solenoid is called for. He has had the codes pulled and none are set. Thinking he may have to have it on the road to pull the codes for the transmission if none are set. Any help would be greatly appreciated and please be kind as I am new here. Thanks
Old Sep 5, 2018 | 08:36 PM
warriorpluto's Avatar
Seems like normal operation for a 4l60.
