Stall question?
Old Aug 18, 2018 | 03:16 PM
Everettreyes's Avatar
Default Stall question?
So I recently installed a cam in my 98 trans am. Everything else is stock except for the obvious parts that needed to get changed for the cam
What I want to know is what would be the size torque converter that is needed now! Any help is appreciated. I'm sure I will be asked what size cam? So it's a stage 2 hotcam. duration@ .050" : 225/236 valve lift: .525/.525' lSA: 110 degrees. With a power band from 2000 to 6500 rpm. Again, any help is appreciated
Old Aug 18, 2018 | 03:54 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Yank SS3600 or CircleD equivalent.
Asking use, daily driver, weekends occasionally, dragstrip ???
Old Aug 18, 2018 | 05:48 PM
Occasional weekend fun, nothing crazy. But some racing with friends on the freeway
Old Aug 18, 2018 | 09:03 PM
2kSilverSS's Avatar
Yank 3600 SS is really good for some DD and weekend fun if you have the $$$
Old Aug 25, 2018 | 04:48 PM
Lsc8's Avatar
I had a 3800 circle d in my mark, which is a bit heavier. I loved it. Builds heat though so make sure you upgrade the cooler if you havent.
Old Aug 25, 2018 | 04:51 PM
Omega Doom's Avatar
Yank PT 4000 and have fun
Old Aug 25, 2018 | 04:55 PM
98CayenneT/A's Avatar
yup, this converter will match your setup good.
The yank ss3600 is definitely a very good all around converter but the pt4000 will give ya a little bit more.
