LS1 Powerglide Conversion
Old Sep 5, 2018 | 02:38 AM
Chads's Avatar
Default LS1 Powerglide Conversion
Got a LS1 with a custom LS1 Converter to suit a Powerglide , I know I won't need the spacer since the converter is built for the Conversion , but I have a Flexplate from a mate that was for use with the spacer , can I use that flexplate
Old Sep 5, 2018 | 10:02 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Which spacer is the flexplate setup for? There is one to go between the flexplate and crank, and another that goes in between the converter and flexplate.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Sep 5, 2018 | 11:37 PM
Chads's Avatar
it's the one that goes between the converter and the Flexplate
Old Sep 6, 2018 | 10:04 AM
LS1Tech Sponsor
That should be a dished LS1 style flexplate then so you should be able to use it with the custom Powerglide converter.
Make sure you get at least 1/8" of pilot engagement into the crank and your converter spacing should be 1/8" to 3/16"
-Dalton
__________________
1-866-726-8358
FTIPerformance.com
Old Sep 7, 2018 | 09:13 AM
Chads's Avatar
-Dalton
Thanks Dalton appreciate it bud ill check once in goes together now clearer head haha
Old Sep 28, 2018 | 08:43 AM
SUPERIORMOTORSPORTS's Avatar
I've been running a ls1 and powerglide combo for two years with a fti sst converter, flat oem flywheel with spacer between flywheel and crank. I wanted to upgrade the flywheel to a sfi unit. Ordered a b&m 20340. When it came in I found out that it is the dished flywheel. Can I use it and move same spacer to between flywheel and converter. Rebuilding trans and cant confirm spacing yet for pilot. Was looking for answers cause im on a time crunch
