dipstick stop bracket ?
Old Sep 5, 2018 | 05:53 PM
jetech's Avatar
Veteran: Air Force
Default dipstick stop bracket ?
When I disassembled my 4l60e I found out there wasn't a dipstick stop bracket installed. The trans pan is an aftermarket aluminum deep pan. Do I need to have one? I bought this trans used knowing it needed a rebuild. The previous owner had a Lokar dipstick which he gave me, but I want to find a factory style tube/dipstick to work with the '71 Camaro it is going in. Thanks
Old Sep 5, 2018 | 10:39 PM
sjsingle1's Avatar
i believe the brackets have been discontinued by GM
Old Sep 6, 2018 | 06:52 AM
jetech's Avatar
Veteran: Air Force
No ill effects from not having the stop bracket installed then ?
Old Sep 6, 2018 | 11:29 AM
sjsingle1's Avatar
the stop serves to prevent inaccurate readings
Old Sep 6, 2018 | 06:32 PM
jetech's Avatar
Veteran: Air Force
Ah... I have no problem with that. I will double/triple check to make sure the level is good. Thanks
