Looking to adapt 1997 4L60E trans to 2003 5.3
Old Nov 29, 2018 | 05:22 PM
Seanbobo's Avatar
Default Looking to adapt 1997 4L60E trans to 2003 5.3
Hey guys I've been searching to find an answer here but seems a different answer from most people. I have a 1997 4L60E from a v8 and I'm wanting to put it behind a 2003 5.3 LS . What do I have to do to achieve this properly? I hear I need an adapter to space the torque converter to the flywheel, and I may have to elongate the bolt holes on the flywheel. Is this all that needs to be done? Any and all feedback appreciated guys. I'm a new member here and am doing an S10 build. Thanks in advance guys. Best site I've seen for information on this type of swap. Also, I want to upgrade the torque converter with about a 2500 stall. Any suggestions?
Old Nov 29, 2018 | 05:24 PM
Seanbobo's Avatar
also do I need to use different starter or will the one from the new LS engine still work for this application
Old Nov 29, 2018 | 09:27 PM
brandon6.0's Avatar
Add crank spacer and elongate flexplate bolt holes. Stock starter will work.
I always measure converter to hub to trans bell housing mounting pad. Thin measure rear of engine etc. This will make certain if u need a spacer or not.
Old Nov 29, 2018 | 09:32 PM
Seanbobo's Avatar
ok yes I did find the adaptor for the flexplate and I have the dished flexplate on mine. So from what I understand I do need the spacer. I have the old flexplate as well from the 97 set up so I will e able to trace to elongate the holes.
Old Nov 30, 2018 | 07:25 AM
MaroonMonsterLS1's Avatar
Treat it as if you're dealing with a th400 swap or similar. You need to use the correct year converter to match the trans...then get a crank spacer and flat flexplate with the correct bolt pattern. Very simple.
I hate elongating the flexplate holes...but I know people do it.
Make sure to doubecheck converter clearance and pilot hub engagement.
