4l80e wiring questions
Old Dec 8, 2018 | 09:53 PM
Greasymechanic's Avatar
Default 4l80e wiring questions
I知 getting ready to upgrade to a 4l80e see a lot of ppl using the harness extension that says it値l work with factory ecm my question is that if I do a segment swap with hp instead can I just extend the wires or will I have to do a repin in the connector
Old Dec 9, 2018 | 06:46 AM
B52bombardier1's Avatar
What are you upgrading from? 4L60E? Or what? Answering those questions first will explain a lot and you might get better assistance here.
Rick
Old Dec 9, 2018 | 01:04 PM
Yea sorry about that I知 upgrading from a 4l60e in a 98 camaro ss and I致e upgraded to a 0411 ecm
Old Dec 9, 2018 | 06:25 PM
Hello,
I think you will need to re-pin your harness to support a 4L80E and I'm not sure that simply using a harness extension will be enough. I'd contact Brendan at the link below for exact details on what needs to change.
http://lt1swap.com/index.htm
Rick
Old Dec 10, 2018 | 02:48 PM
Thanks got what I needed off the website
