B/M deep pan w/ stock filter?
I have a '95 GMC Sierra w/ the 4l60e.
Thanks for any help. Jake
The point of the filter extension is multi-faceted.
1. Places the filter at the bottom of the pan...helps keep the filter covered in oil regardless of how hard you launch/corner
2. With the filter at the bottom, the pan supports the filter so it doesn't hang and fall out of the pump...if it's not supported, it will likely fall and the pump will suck air.
3. I agree with eliminating the extra opportunities for leaks...but if the truck filter won't be placed at the bottom of the pan like it would be in a stock app...you need the filter extension
