th400 reverse and third gear problems
Old Jan 8, 2019 | 09:13 PM
Johnny Myers's Avatar
Default th400 reverse and third gear problems
My the 400 will shift into gear only when it is cold,and third gear only when going up hills,any suggestions would be appreciated
Old Jan 8, 2019 | 10:07 PM
MaroonMonsterLS1's Avatar
3rd gear up hills sounds odd. I would check fluid level for starters.
reverse and 3rd share one thing in common...the direct clutch. Chances are it's worn out if both gears are having issues
Old Jan 10, 2019 | 10:12 AM
performabuilt's Avatar
LS1Tech Sponsor
Not as mentioned to sure about the uphill part but for reverse sounds like the ring surface in the direct clutch housing is worn . Common problem also need to check center support and bushings as these are usually the cause ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
