Transmission shift issue 4l60e
Old Jan 15, 2019 | 03:54 PM
Josh Boone's Avatar
Default Transmission shift issue 4l60e
Just got my transmission repaired and now when I manual shift down from 1st,2nd and 3rd and get on it it doesn't want to shift (unless i let off) but if I just shift from 1st,2nd or 3rd without flooring it it shifts just fine.
Old Jan 16, 2019 | 12:43 PM
Josh Boone's Avatar
bump.
Old Jan 16, 2019 | 11:47 PM
RevGTO's Avatar
Pontiacerator
Josh, we have an automatic transmission forum on this site. That's where you gotta go with this.
Old Jan 17, 2019 | 08:08 AM
Kfxguy's Avatar
you should be able to tune that out but the reason its likely happening is you either have internal leak ( valve body bolts left loose, cut oring, cut lip seal) or your clearances are way too loose, probably on the 2-4 band.
