Where to buy th400 & converter?
Here is the progress thus far
https://ls1tech.com/forums/forced-in...-thread-3.html
pretty much everything you need aside from the shifter.
-Dalton
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Then as far as converter, the car is stock 6.0 with stock cam, rod bolts & upgraded valve springs. 3.42 rear and, probably run enough boost to hit the 7-800hp mark. Point me in the right direction.
Do you have future plans to upgrade the trans and go to transbrake? If so i would do a reverse pattern now so you're not having to change your shifter later on. If not and you would like to retain the engine braking feature then i would go with the forward pattern. For the converter I'd like to plan for future transbrake if that is a plan. If not then we can do our SR series with a turbo stator. Guessing the car weighs around 3300lbs?
1-866-726-8358
FTIPerformance.com
As for the converter I would say the car will be closer to 3700#
