Faulty speed sensor???
Old Feb 24, 2019 | 03:07 PM
onefast ls1's Avatar
Default Faulty speed sensor???
My mph hand is glitchy and I知 experiencing my trans going from 2nd to 1st at part throttle then it値l go back to 2nd
Old Feb 25, 2019 | 08:33 PM
performabuilt's Avatar
LS1Tech Sponsor
Bad sensor is likely , But also check that the magnet in it has not just collected a lot of material this also can cause odd MPH readings and on very rare occasion the reluctor wheel managing to move on shaft is possible but least likely.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 26, 2019 | 11:08 AM
ok well I had recently replaced the sensor do you think I should swap the wires running to the pigtail if that would help anything
Old Feb 26, 2019 | 11:16 AM
mrvedit's Avatar
Moderator
I would first check the connectors to the sensor; you may need to splice in a new pigtail. If that doesn't help, you might try yet another sensor, else the possible problems that Performabuilt mentioned.
Old Apr 15, 2019 | 06:21 PM
I知 still having issues after I installed a new pig tail. Now the mph is still glitchy and when the car shift from 2-3 it痴 a jerky lunging feeling coming from the trans. Car gives no codes
