4L80E swap
Old Apr 1, 2019 | 04:06 PM
85LSXTRUCK's Avatar
Default 4L80E swap
I have an LS3 that I am putting a 4L80e behind. What flex plate and spacer should i buy for this swap. Is there a way to do this other than a spacer or? Trying to gather parts to throw this LS3 into my gbody.
Old Apr 2, 2019 | 07:27 AM
MaroonMonsterLS1's Avatar
There is a sticky at the top of this forum section that details flexplate/converter options.
Yes you can do it without a spacer.
You can get a custom converter with longer pilot, and a bolt pattern to match your stock flexplate
you can use a crank pilot adapter sleeve and then "hog out" the bolt holes in your flexplate
Go read how 999 other guys have done this...it's quite simple
Old Apr 2, 2019 | 04:55 PM
85LSXTRUCK's Avatar
Thanx for the help, yes i just ran through all the stickies. Seems like most of the info is Ls1 based. Will this e bay item allow me to do what I am after. I need the flex plate anyways. https://www.ebay.com/itm/Flexplate-f....c100040.m2060
Old Apr 3, 2019 | 07:04 AM
Take whatever info is out there for the LS1 and use it for your ls3
Same crank length
same bellhousing pattern
