For Builders and DIY Enthusiasts
Old May 3, 2019 | 07:17 PM
vorteciroc's Avatar
Originally Posted by MaroonMonsterLS1
When is the last time you've had a pump seal that came out of a transtec kit that leaked? (not counting installer error or a walked bushing, etc)
Never...
When's the last time you've had a pan gasket leak...when installed properly with a good pan...never. Cork, duraprene, molded with steel torque limit inserts, etc. Doesn't matter
I bet these people you'll spend all this time and energy on making sure they get " the best metal clad seal known to the history of man" will be the same people that don't vacuum check a valve body, don't check the pump gear clearances, etc
I appreciate an attention to detail, but I'm not sure this is the best area to focus the efforts.
Good luck tho!
All very true.
I have multiple small projects going on at one time, this was one of them.
It is done. I thank you for your input. :-)
Old May 4, 2019 | 03:59 AM
sjsingle1's Avatar
how many times has someone come on here and said........where can I get a total kit of the specific parts I want instead of buying a generic total rebuild kit and having to spend more for those specific parts I really want ?????
I have lost count............
I am fixin to have to do a rebuild and thats the kit I want !
Old May 4, 2019 | 08:18 PM
PBA's Avatar
PBA
If you are looking to get "complete" rebuild kits, then I offer the most complete rebuild kits and I tailor them to match what you have as far as horsepower/torque, what is done to the motor, any power adders (nitrous, supercharger, turbo), rear end gear ratio, the torque converter stall and diameter, what is the vehicle used for, daily driver or weekend warrior, and how you drive. Conservative, moderate, moderate/aggressive or aggressive. I always offer help and or what is needed, even if you do not spend a penny with me.
