4l60e to 4l80 swap
Old May 14, 2019 | 03:56 PM
Thumpn's Avatar
Default 4l60e to 4l80 swap
I have a done a swap from a 97 4l60e to a 02 4l80e, with a CK performance D3 valve body. And upgraded internals. I have changed in Hptuners to the 4l80 in trans settings and changed the gear ratios for the trans . I also changed rear gears and did the gear ratio call changes . But now it acts like it’s in limp mode in all shift positions from park to drive. Is there something I missed In Hptuners? The 4l60 was a 1 switch setting is it the same for the 80? Also I did move the wires in the trans plug for the 80 and moved the wires at the ecm for speed sensor.
Old May 14, 2019 | 05:38 PM
Thumpn's Avatar
One other thing I noticed is it shift position shows it is in d1 but it does not go into 1st it stays in second gear and the speedo is about half of what it should be
Old May 14, 2019 | 07:57 PM
MaroonMonsterLS1's Avatar
if you just changed the drop down menu from "4l60e" to "4l80e" then you haven't achieved jack squat.
You need a segment swap.
That drop down menu shouldn't even be in there because it doesn't do anything
Old May 14, 2019 | 08:18 PM
Thumpn's Avatar
so what is a segment swap? i am not familiar with how to do it?
Old May 15, 2019 | 01:05 AM
Thumpn's Avatar
Ok so now i have done segment swap is there anything i need to change in the settings, to make it work with the Ckperformance D3 valve body? I only ask since with the D3 you have to disconnect the EPC wirefrom the ecm , cause with this valve body that wire is now the trans brake activation wire and the trans pressure is set at 220psi in all gears.
below is the tune file w/segment swap
Old May 16, 2019 | 06:43 PM
jlaudioholic's Avatar
Default Wiring
Edited my post, as I reread your post and you did the rewiring.
