4L80e temp issue/ lockup
Old Jun 3, 2019 | 07:55 AM
21jeremy's Avatar
Default 4L80e temp issue/ lockup
Hey guys, I converted to a 4L80e behind my LSA. New converter from CirleD and can’t get the converter to lockup. Tuner said the trans temp is flipping back and forth from actually to -40 not allowing the converter to lock. He can manually lock it on dyno but won’t lockup on its own. Sound like temp sensor issue? Or TCM issue?
Old Jun 3, 2019 | 09:20 AM
blown94's Avatar
Sounds like a bad connection, wiring issue. -40 is like open circuit. The harness had to be repinned or added if u were manual. I would suspect a wiring issue before the sensor our trans internal harness.
