Wiring connectors - trubble
Old Jun 29, 2019 | 08:53 PM
jalfredprufrock's Avatar
Default Wiring connectors - trubble
Having a tough time trying to push the wiring connections together...these are on the neutral safety switch area. They slide okay to the end of the first 'rib' on the rubber/plastic thingy
This is a 1995 4l60e. Surprised to run into this difficulty. Any special trick to reconnecting them? Couldn't find anything in the stickies or anyplace else.
Jake
Old Jun 29, 2019 | 10:01 PM
bbond105's Avatar
Put a little grease on the rubber seal and around the inside edge of the switch.
Old Jul 1, 2019 | 04:56 PM
JeepinJeremy's Avatar
The NNS plugs have a glue on them. You need to heat up the plugs and connector with a hair dryer or heat gun and they will slide back in.
Old Jul 1, 2019 | 10:51 PM
brandon6.0's Avatar
^^^^ this!! Do the same to unplug them!
