Transmission Mount doesn't align?
Old Jul 1, 2019 | 12:22 AM
bigred8944's Avatar
Default Transmission Mount doesn't align?
I have a 98 z28 with an iron block, ICT solid mounts, th350 trans, jegs poly trans mount (energy was out of stock when I ordered), and a midwest chassis cross-member. My trans mount does sit anywhere near the crossmember. Should I try to build a spacer to go between the crossmember and the mount or should I do something else to fix it? I tried looking through old posts and didn't find much.
Old Jul 1, 2019 | 07:41 AM
MaroonMonsterLS1's Avatar
As in...the hole is too far forward/too far back
Or it sits too low and there is just a gap?
Old Jul 1, 2019 | 10:13 AM
bigred8944's Avatar
The mount just sits too high.
Old Jul 1, 2019 | 10:59 AM
check angles. Make sure driveshaft and pinion angles are happy...shim/adjust the trans mount as needed.
Old Jul 1, 2019 | 01:19 PM
bigred8944's Avatar
thank you! that's is what i was planning to do but i hadn't heard of anyone else doing that so I thought I would ask.
