New 94
Old Jul 18, 2019 | 05:15 PM
alan lewis's Avatar
Default New 94
I'm trying to restore a 1994 Silverado Short bed, 5.7, 4l60e, stock. IV replaced the transmission with a professional rebuild. Test drive had 1,2, and 3,
; No OD; Never shifted put of 3. It will manually shift onto 2 but have to manually shift na k to 3.
I've replaced the following: TPS, VSS, ECM, Ignition Switch, O2 Sensor and MAP Sensor.
I also removed the external wire harness to the tranny. The ECM is showing no code. The shop in Ohio who built the tranny sent two new solenoid and I installed them. Iv cleaned and tested as naby grounds as i van find.
I never dreamed that an Chevy world prove to be a money pit.
Does any ons have any suggestions
Old Jul 18, 2019 | 07:34 PM
Welcome to LS1Tech! Re-post this question over in our Automatic Trans section of the forum, and I’m sure you’ll get plenty of help over there. Certainly some of those guys have worked with what you’ve got.
