Strange vibration, torque converter??
So I've recently got my car back running, but now I'm about ready to pull my hair out. The car is making a weird vibration at idle, almost like a growl... not really audible, but more of ax feeling. Seems to do it more when the transmission is up to temp (th400), feels a lot like loose bolts on a torque converter.... but the bolts are tight. I've never experienced a bad torque converter, so here's the question. If it were a bad torque converter, would the vibration go away once the car is put in reverse? I've wrestled with this, because the converter is a constant, but I'm really at a loss. The car drives fine, stall characteristics haven't changed (9.5 PTC 5200 true stall speed). Only 2 things I've changed since I reinstalled the motor are the passenger side motor mount and the transmission mount as it was destroyed (didn't use solid mounts). Any suggestions? Oh, and one more thing, the feeling seems to change, depending on steering input. If I weave to the left, it intensifies....to the right almost disappears.
