4l80e air test
Old Jul 31, 2019 | 10:52 PM
jertho's Avatar
Default 4l80e air test
when i air test intermediate clutch though center bolt it leaks out small plug on center support should it or is little plug **** ' atsg book # 530 tk you
Old Aug 3, 2019 | 07:43 PM
Tranzman's Avatar
Yes the 2nd clutch is a feed bleed set up it will leak through the orificed cup plug. It should air test with 40 PSI though.
