4l60e swap question
Old Aug 9, 2019 | 02:08 PM
fischdogg1's Avatar
Default 4l60e swap question
Would a 1996 2 wheel drive tahoe transmission work on my 1997 trans am? As long as it's a 1996-97 the shift points should be the same right? I'd just swap out the servo's right?
Old Aug 9, 2019 | 02:12 PM
MaroonMonsterLS1's Avatar
You'll have to swap tailhousings also.
The trans am will have a torque arm mount.
Just take a quick glance and ensure the input shafts are the same. 99% chance they are but just look
Old Aug 9, 2019 | 02:30 PM
fischdogg1's Avatar
Cool. Thank you !
Old Aug 9, 2019 | 07:14 PM
fischdogg1's Avatar
I found out that it’s 4 wheel drive. That won’t work will it ?
Old Aug 11, 2019 | 12:04 AM
vorteciroc's Avatar
It will only work if you can have a two wheel drive main/ output-shaft installed along with a two wheel drive tail-housing.
Old Aug 12, 2019 | 07:42 AM
No it won't work...you'll have to tear the transmission all the way apart to change the output shaft...at which point you may as well just do a full rebuild with new parts.
