4l60e
Old Sep 27, 2019 | 12:37 AM
ldr's Avatar
ldr
Default 4l60e
I can’t find a definitive awnser. Can I use a 4l60e from an 05 Colorado with a 3.5l in a swap to an ls. I know bellhousing has to change but I can’t find an awnser on what input shaft that engine used. Rockauto is saying it’s a 300mm. Does anyone know?
Old Sep 27, 2019 | 07:38 AM
MaroonMonsterLS1's Avatar
post #4 https://ls1tech.com/forums/automatic...-shaft-v6.html
Identify which shaft you have...the pump will match the shaft.
Funny part is...any of those 3 options you see CAN be made to work with an LS, sbc, bbc, 4.2, 3.5, etc
Just make sure the converter/flexplate matches the input shaft and get the spacing right...and it will work
