2000 Corvette LS1 and 2002 Silverado 4l60e
I'll start with my setup and what I am attempting to accomplish- I have a 2002 Silverado with a 4.3 v6 and I have recently purchased a 2000 Corvette C5 LS1 engine which I will be swapping out. I have searched through many articles here and on Google, but can't quite come up with any concrete answer to my question. I am wondering how I am to go about mating the LS1 engine to my existing 4l60e. I have read I should use a flex plate from an F-Body Camaro which uses the same engine/tranny combo and that makes sense. I can't however find any information on the proper torque converter to use. Another thing that is throwing me off is the mention of different input shaft lengths between the truck/car variations of the 4l60e. I would just like to know ahead of time what to go after for my parts search.
This is my first attempt at a motor swap, so maybe my questions don't make sense to more experienced wrenchers in the forum. Any help would greatly be appreciated and I am looking forward to hearing what others have to say. Thanks
I would grab the bell-housing, turbine-shaft, stator-support, torque-converter, flex-plate, engine mounts, and engine oil pan.
If the truck is slammed down low to the ground and the truck oil pan becomes a problem... go with a LS2 Corvette oil pan instead.
I personally would much rather have the added oil capacity/ cooling should the truck oil pan fit.
I also would most likely use the truck accessory/ serpentine belt/ balancer/ water pump set-up as well.
This will keep things as simple as possible, with no need to worry about mixing and matching components.
Ive installed them all diff which ways etc. I used them all with success!
Most likely you will need to buy a turbine-shaft, stator-support, and torque-converter for a 2002 5.3L Silverado (300mm design) as I said above.
The bell-housing may fit... but most of the time, the bell-housing you have will be a 1/4" shallower and will be missing the 12 O'clock bolt hole compared to
the 5.3L bell-housing (GM #24206953).
Again... I would just buy a 2002 5.3L Silverado bell-housing, flex-plate, turbine-shaft, stator-support, and torque-converter.
It does NOT get any easier than this!
I just did a swap and the 2003 4.3 had the old style converter. Sure it'll bolt right up with the right flexplate and spacer, but it's the old style converter and bellhousing.
And good luck putting the corvette oil pan in the truck. FWIW the whole STOCK oil pan sits above the frame on that year truck.
Now if it has a smaller v6 input shaft (small pointed tip on end) u will need to oblong the flexplate holes a lil bit and use a crank spacer. $25 part.
https://www.lsenginediy.com/ls-swaps-oil-pan-guide/
