4l80e bellhousing question
Old Oct 10, 2019 | 01:04 PM
kott0n's Avatar
Default 4l80e bellhousing question
I keep reading all 2000+ 4l80e have the top bellhousing bolt provision that the LS engines utilize.
My question is since the Express vans had the Vortec 5.7l up to 2003, do these 4l80e's have top bolt provision? I figured it could go either way. GM could of been using the Vans to use up the last of the old stock which is why you see vortec 350 in them and it wouldnt be a stretch to think they would be using old stock 4l80e, without the top bolt provision.
I understand it isnt required to use the top bolt location but for information sake, do you think the 2000-03 express vans have the new style bell?
Old Oct 10, 2019 | 01:36 PM
kott0n's Avatar
Price difference on these units from the yards are pretty significant. A 4l80e from behind a 5.7l in an 2002 express van is coming in around $600 and one from a 6.0 is around $900.
I got a local yard who will do a 2002 4l80e from behind a 5.7l Express van but provide an LS converter/flexplate from a 6.0 for $630. This seems like the best route but Im curious about the bolt pattern.
Old Oct 10, 2019 | 02:27 PM
MaroonMonsterLS1's Avatar
The bolt pattern is the same.
ALL 4l80e will bolt up behind a sbc, bbc, LS, LT, etc
That top bolt is NOT needed...its not a determining factor at all for strength
The top bolt also won't hurt anything if you try to use it with a SBC that obviously doesn't have the top bolt provision in the block
aka it doesn't matter
Old Oct 10, 2019 | 02:57 PM
Jays_SSZ28's Avatar
Yes, they (what is quoted above) all have the top bolt hole.
Maybe the price difference includes the lower dust shield which is actually a structural part of the bellhousing when a 4L80E was used behind an LS engine.
Old Oct 10, 2019 | 03:04 PM
kott0n's Avatar
Thanks a lot guys. Like most things, I was over thinking this.
Much appreciated.
