4L70E 1st Gear shifting issue
Old Dec 12, 2019 | 07:29 PM
batmanntexas's Avatar
Default 4L70E 1st Gear shifting issue
Hello,
Helping a buddy with his 2007 Avalanche with a 5.3L. He has recently developed a 1st gear shifting issue. It will not shift out of 1st gear, under any condition, without letting off of the gas. The other gears shift just fine after the 1-2 shift is made. Reverse works just fine as well. Log file and current tune are attached.
I appreciate any help.
File Type: hpt
File Type: hpl
Old Dec 13, 2019 | 08:46 AM
Anybody?
Old Dec 13, 2019 | 08:52 AM
MaroonMonsterLS1's Avatar
It's been up for less than 24 hours.
Relax killer.
Alot of guys that have seen this post are probably not hanging out on their tuning laptop to be able to pull up the log and the tune. I'll take a look when I get home from the shop.
Old Dec 13, 2019 | 02:54 PM
What??!! I thought there was a whole army of you guys just hanging out on your laptops waiting for my next posting...
Thanks for taking a look, though.
Old Dec 13, 2019 | 08:15 PM
vorteciroc's Avatar
Sorry I do not read Logs.
Any Diagnostic trouble codes?
Any Freeze-Frame data?
Is this a new problem?
How long ago was the 4L70E transmission swapped into your vehicle?
How many miles are on the transmission?
What happened to the original transmission?
Have you ever serviced the transmission?
Have any transmission services or parts replacements been performed recently?
Any other issues with the vehicle?
Any modifications to the power-train and especially the transmission?
Have you checked the transmission fluid level?
Have you checked the transmission fluid condition?
Have you checked the transmission line pressure?
Is this a new tune?
Have you spoken with the tuner?
Do you have another tune you can try?
Old Dec 13, 2019 | 11:41 PM
sorry i do not read logs.
Any diagnostic trouble codes? No
any freeze-frame data? No
is this a new problem? Yes
how long ago was the 4l70e transmission swapped into your vehicle? Original transmission
how many miles are on the transmission? 120k
what happened to the original transmission? See post #1
have you ever serviced the transmission? Unknown
have any transmission services or parts replacements been performed recently? Not in the last 6 months. Prior to that i have no knowledge.
Any other issues with the vehicle? No
any modifications to the power-train and especially the transmission? Small cam in stock motor (216/223)
have you checked the transmission fluid level? Yes
have you checked the transmission fluid condition? Yes
have you checked the transmission line pressure? With the hpt vcm scanner. No physical gauge.
Is this a new tune? No.
Have you spoken with the tuner? Yes
do you have another tune you can try?
tried three other tunes, same results.
Old Dec 14, 2019 | 07:52 AM
bbond105's Avatar
Are you sure it is shifting 1-2 and not 1-3? Check your 2-4 servo travel, it should be .075"-.125".
Old Dec 14, 2019 | 06:19 PM
vorteciroc's Avatar
120K and no trans service... plus the new problem you have...
Well, I would remove the transmission and have a look inside then. Fix and overhaul the unit... It lasted a long time.
Also... Sorry to be the bearer or bad news... but there are no 2007 Chevy Avalanche vehicles produced with a 4L70E transmission.
Either it was swapped into the vehicle; or someone lied to you. Sorry.
Old Dec 15, 2019 | 08:52 AM
Thanks for the response. I have already recommended to my buddy that he have the transmission rebuilt, just his funds are tight right now.
Also, to my knowledge, there are no external differences between the 4L60E, 4L65E, and 4L70E. The only difference is internal modifications that GM made over the years to in improve the reliability & performance of the original 4L60E.
I may be wrong about my 4L70E designation, so I'll have to dig into that some more.
Old Dec 19, 2019 | 03:00 PM
antoine's Avatar
Does the speedo work
Old Dec 19, 2019 | 07:52 PM
Yes, the speedo works.
